Engine Rattle (tick) between 2500-4500 rpms, searched with no good answer
MIKE93SVT
so i picked up a sweet 89 ranger for a DD, it's a 2.3, 5spd, standard cab and box. it has 159k on it and the motor was replaced at 100k. anyways, if you rev the motor, or drive through the gears there is a rattling noise similar to what a heat shield would sound like.
i checked the main muffler and pulled that heat shielf off, then checked the one on the exhaust manifold and pulled it off. the noise is still the same and i've tracked it to under the valve cover
it is evident above 2500 rpms or so (no tach) and is a little louder as it comes down. if you shift early you won't hear it, and nothing at idle. but if you go through the rpms a little bit it will rattle and you can definately hear it as the rpms come down. i'll get a video of it when i get home. it really sounds like a heatshield rattling, but i 've removed them and checked the one on the cat, which is good.
i'm assuming it's something to do with the valve train. i've searched and didn't find a good answer to explain some similar problems. i just changed the plugs and wires (made the noise before) just to get it running better. this is my last problem to fix before it'll be top. hopefully i don't have to pull the valve cover cause it looks like the intake has to come off too. i think i'll try some seafoam as well, but doubt that will fix it. it's definately not detonation either.
sorry for the long post, just wanted to explain everything. and i'll post the video up tonight
thanks,
mike :icon_cheers:
also, the noise goes away once you go above approximately 4500 rpms, which i only did a couple times. so it's only doing it between 2500 and 4500. seems like the valve adjusters or whatever these little motors have can't keep up with the acccel and decel of the motor and the rockers are tapping or something
The lifters are going bad. I had that some problem with my Turbo Coupe, replaced the lifters and the problem was gone.
thanks for the input. can i get the valve cover off without pulliing the intake? guess i'll start pricing out some lifters around here
If I remember right I think I just took the upper intake off, but I think the Ranger intake may be different from the Turbo Coupe intake. getting the followers back on can be a real PITA.
awesome, gonna keep doing some research and figure out the best plan of attack. i'd like to get it done this weekend.
well as happy as i am to say it's fixed, i'm embarassed to say to say how, haha. i said the answer earlier, the lower heat shield on the car was solid, but the upper one wasn't. that was the main source. also the egr tube was lose and was rattling as well. it's all good now and turned out to be simple and a mistake on my part, oh well. thanks for the help
