Can you use a 3 inch tensioner pulley as an idler pulley. Instead of the 3 1/2 inch stock idler pulley. If so all I would need to do is get a shorter belt to make up for size difference.
You probably won't need a shorter belt... the factory 3" - 3 1/2" tensioner/idler pulley combination on my '00 made my belt way too tight and was bending my tensioner out of alignment, so I swapped in a 3" pulley for the 3 1/2" and the belt now fits perfectly.
For
