Thrashingrage
- Aug 3, 2012
Hey all,
I am gearing up to pull the 2.9 out of my '90 Bronco II. I plan to change all of the leaking gaskets and seals, swap the clutch to a 4.0 one, put on some headers, and put in a high-volume oil pump. I realize that this question is probably rather obvious, as this will be the first engine that I have ever pulled, but I am wondering where exactly the lifting sling or chain actually bolts to the engine, as I don't see any sort of lifting "ears" on the heads. Does a chain somehow bolt up to the holes in the top of the cylinder heads where the exhaust outlets are, similarly to how the accessory brackets bolt to the heads? Any help will be greatly appreciated.
Thanks,
Josh
Thanks,
Josh
