hey-you
- Mar 1, 2008
- Automatic
Okay, I've not figured this out yet. Here is what happens:
After the engine warms up (2+ minutes) the engine will do the following:
1. make a additional roaring noise (like I've plugged a shop vac in) and I be imagining things but there is also a slight vibration.
2. if I'm driving, it all seems to go away, especially if I accelerate slightly, nothing really specific happens except the engine rpm doesn't seem to dropbelow 1200 if I'm coasting or moving slowly throught town.
3. if I'm stopped and the noise stops then it is immediately followed by a drop in engine rpm, last time it happened, it dropped to a stall.
Other info: about 10 months ago I had the transmission rebuilt, and I know that the vacuum line to the heater control valve has gone (since its winter and I have heat I was sitting on fixing it till spring). Finally, I know the oil sending unit is sticking on cold starts.
Any thoughts? I've not found much in my Haynes manual.
