oodannyboyoo
- May 9, 2015
- South Florida
- My credo
- Just because it hasn't been made doesn't mean you cant build it
I have a 2001 ford ranger 3.0. I put in a Royal Purple 5w-20 HPS oil and a Royal Purple oil filter within the last month or two and noticed that the oil pressure takes a loooong time to read. Itis sporadic at times and will read 0 at a cold start then jump to normal operating pressure then back to 0 multiple times and the needle wil sometimes shake and be sporadic until the engine gets hot enough and stays at operating pressure. This only happens on a cold start, if the engine is warm it will reach and stay at operating oil pressure. What could be the cause for this? Should I be worried of damage to my engine? Is it a sensor? I hear no abnormal noise and the engine runs great even when its having trouble finding the right oil pressure. It doesnt burn any oil either, its been right near full on my dipstick on a cold engine since ive changed it. Please help, thanks in advance!
