mike367
- Mar 13, 2010
- Automatic
hey guys, need some help with an oil leak. Keep in mind I am not a mechanic but have done some stuff. I noticed a small oil puddle at the beginning of summer under the truck directly below the oil drain plug, also noticed a small repeating drip on the plug itself. At the time I was was knee deep in changing both wheel bearing hub assemblies and half axles, so I put the leak on the back burner.
Fast forward two months to now ( due to financial issues) I have finally completed the front end and am ready to work the leak. The truck has not been started for the two months and there is no oil showing on the dip stick. I crawl under and loosen the drain plug expecting no oil. I was wrong, oil poured out so I quickly re tightend the plug and wiped it down, no leak.
My guess is it's leaking somewhere between were the oil dosnt show on the stick and the pan. If it's the pan I do not have the tools to change it so would have to consult a shop. Any idea on cost ? Thanks for your time. Mike
