Primosboy
Okay so I'm going to reillustrate this problem. 87 Ranger 2.9 v6. Idles erratically and idles fine on and off. Misses durring idle and throughout idle speed range. While it's idling good...it will hold 3,000 rpms in nuetral for anywhere from 5 seconds,to a good couple minutes...but then it starts sputtering and and the needle will go waaaay down and it has no power. If I continue to press the gas it will just sputter and quietly backfire somewhere in the engine. It does this when it's running cold and when it's warmed up. Also while driving...same thing. It will be fine for anywhere from 5 minutes to a half hour,but eventualy it looses all power and sounds like the timing is way off. I've ran codes,replaced the fuel filter,plugs and wires,ignition module,vaccuum systems good,alternator's good,timing is perfect. I'm running out of ideas. HELP ME PLEASE!
