So engine codes and running like shit usually go together, but here is what I have coming up.
I spoke to the tuner yesterday and he basically said, "with a stock motor, stock MAF, stock ECU, it should run fine."
Well, it doesn't. still does that stupid "camming" shitty idle crap after it warms up. When it is cold outside, it won't even try to start. all the lights come on the dash, but turn the key and nothing. pull it in the heated garage, and after 5 minutes, it fires right up. He did say to bring it to his shop after we get it painted to get a custom tune for the truck, but I'd like to try and figure out what is causing these issues 1st.
Here is a list of all the codes:
P0708 - NSS/Transmission Range Selector
P0443 - EVAP Circuit
P0453 - EVAP Circuit
P0135 - O2 bank 1, Sensor 1
P0141 - O2 Bank 1, sensor 2
P0155 - 02 bank 2, sensor 1
P0161 - 02 behind cat
P1451 - EVAP Circuit
o2 sensor codes are self explanatory, but the rest, I am at a lost. I am going to research and edit the post today to see what possible causes are out there.
Anyone of you all running the v8 have these pop up?
** Adding this from another forum to check before replacing O2 sensors
Do you have an owners manual, if so look in the under hood fuse distribution box & check 15 amp fuse mini fuse position 13. Its for the O2 sensor heater circuit & about 4 other things. Make sure the fuse is good & its socket is corrosion free & snug fitting. While you have the fuse out, at KOEO check for B+ voltage with your multi-meter set on the 20 volt DC range to make sure you have battery voltage that far. If so, check for B+ at the O2 sensor electrical connector & KOEO. If no voltage there, you have an open circuit in the B+ O2 sensor heater wire between the fuse & O2 sensor electrical connector. So look for rust, corrosion at the O2 sensor electrical connector pin/socket, or signs of a pinched or cut wire or damaged insulation. Look any place the wire touches something that moves, vibrates & or is hot. Do a wiggle test at the O2 sensor end to see if you have broken wire strands under the insulation.
