Engine Bore??
danger_ranger05
Reedy, West Virginia
I know you can bore fourwheelers out to get way more power out of them, I was wondering if you could bore out a V6 engine. If you could, im curious about what resources i could look up. I own a machine shop so I can do alot of things, just need the know how:icon_thumby:
The 4.0L OHV is a 3.952" bore with pretty thin cylinder walls.
You could probably bore it out larger, but the larger you get the shorter its life will be.
iirc, a .030 overbore is the max even though a .048 would make it an even 4.000"
I was gonna bore mine out when I rebuild it, but I decided before that I was just gonna force feed it and that an overbore would just shorten its life.
Usually boring is used to freshen up the cylinder walls, not for more power... Stroking usually is used to make more power...
a 030 overbore on a 4.0 is only good for about 3 cubic inches
How much power increase do you think you are going to get out
of 3 additional cubes on a 245cid engine?
AD
