chris78
I have an 86 bronco II eddie bauer. I wanted to try and figure some things out that have been changed by previous owner. Things were cut, rerouted, and other odd stuff. I'm not real familiar with b2's or the 2.9 engine. Maybe some of you who are in the know can take a look at these pics and tell me whats suppose to go where and what is missing.
The first pic shows driver side engine bay. The thing circled in red is missing something. The blue circle has a yellow wire that goes through firewall, spliced into a red wire. Then there are a few wires circled in yellow that are cut, and a connector that isn't plugged into anything.
In the below image you can the ac system is wired funny.. There is an adjustable thermostat that looks like it doesn't belong. The orange wire is traced over to the compressor. The other wire, yellow, goes through fire wall, im guessing to the ac switch? The thermostat sensor is shoved into the black housing, i'm assuming contains some kind of ac coil? and from other photos i've looked at in the forums there is something missing out of the black housing, the top hole circled in blue.
In the below image there's a plug on the passenger side not plugged into anything.
Any help appreciated!
