Emission Controls - Vapor Canister Lines
RonSerling
High in the mountains of San Bernardino National F
ummmmm 4" could be 6 but its a TTB and the little bugger varies from time to time !! LOL
Hi all !!!,
I have a 93 Danger Ranger with a 4.0 in it. Just got back from the smog test station where everything was fine until he tested the line to the vapor canister. He said it failed probably because there is a leak in the line from the canister to the fuel tank. He said to replace it and also to check that the gas tank filler hose, which is new, clamps are tight. My question here is I have checked a number of supply houses and no one seems to stock the hose from the canister to the tank so I am wondering what the size, I.D., of it is so I can just get some to replace it. Also I can see it down on the canister but does someone know where it connects back at the gas tank ??? Any help would be appreciated !!
Thanks
At the tank it attaches to a little plastic thinger on the top. Shape, size and exact location can vary depending on year and body configuration.
