Speed limiter on an '86-'87? What speed limiter?
My 1986 didn't have any VSS. There were no tone rings and no VRS's anywhere on the vehicle (except inside the distributor). The end of the speedometer cable had ONLY a drivegear and an O-ring on it; no sensor. Vehicles of that vintage with cruise had a speed sensor around the driven end of the speedometer cable.
The '87 tach cluster I grabbed for it had a fully punched instrument cluster, just no bulb. That was easily fixed. But of course I had to run the wire for it.
But yeah, the PCM isn't relevant to the EMISS light. A simpler solution to taking the module apart (aside from just resetting it) is to pull the EMISS bulb (and use it for the CEL perhaps).
the instrument cluster is many times harder to get out than that stupid little Infered mileage sensor module.
That module involves emptying the glovebox and removing two screws.
the instrument cluster? it's Eight screw just to get the dash facia off of a Gen1 Ranger then the four screws for that and the two connectors (what I call the double jointed wrist trick)
and as for resetting it? I've crossed paths with ~30 of those modules
I have yet to find one that WOULD reset no matter how many times the button was pushed... the problem is that there is that the button is a conductive rubber disc (that dry rots) and a "pad" on the circuit board
that oxidizes... thus it simly CANNOT make contact
Mabey they would have reset back in 1990 or so, but Mine already wouldn't
reset in 1995. I doubt you'll find one that's resettable now.
as for RABS?
On an '86-87 Ranger? No.
RABS was Bronco2 ONLY in 1987.
Rabs was introduced for rangers in 1988
(and then mostly on the supercabs)
My '88 short box didn't have it and my '87 Bronco2 did.
BTW Mike, you keep forgetting that you live in LaLa land and what you find has no connection (rational or otherwise) to what the REST of us NON-Cali people will find on vehicles.
YOU keep forgetting that.
I'll keep reminding you.
My NON-Cruise, NON-automatic 2.9 Ranger supercab came from the factory with a VSS on the transmission.
It's there for the 115mph speed limiter provision built into
ALL 2.9 computers, but for practical purposes only the 2wd trucks actually had the speed limiter, because the only way a
gen1 4x4 could get to 115mph was AFTER the Myth Busters
team installed a rocket motor in the bed.
IF you have cruise control on a Ranger 1994 or earlier
you have a VSS.
If you have an A4LD it won't WORK without a VSS.
TCC is trigered on a road speed parameter suplied by? VSS.
Later A4LD's 3-4 shift solenoid? VSS.
I've "fixed" an A4LD that wouldn't shift into OD
by taking the vehicle on a road test and IGNORING the transmission.. I tried to activate the cruise control...
when it wouldn't work I replaced the VSS, and suddenly
it shifted into OD AND wonder of wonders the cruise control
suddenly worked!
I knew what I was looking for of course.
(If it had been something else that $11.50/100#
offered by the scrap yard would have been too
much temptation to resist
The speed limiter was a wonderful idea, but it was kinda pointless because I only found it ONCE and I was specifically looking for it at the time.
AD
