yellowoctupus
I found when I remove the starter solenoid wire (from the ignition) my truck jumps up in idle, and when it's put back on, it drops back down. I took readings at different states of running truck, can anyone make sense of them??? These voltages were measured at the ignition switch grey/pink wire which should be along the same line as the starter solenoid trigger wire. (BTW, this is in reference to the last 6mo of my intermittent running posts with my 88 2.9 Ranger..I wouldn't think I'd have voltage at this wire unless the truck was being STARTED, but these were all very steady (non flucuating) voltages)
Running @ ignition (solenoid wire on)
In Park = 0.071V
In Gear = 14V
Truck not running @ ignition (solenoid wire on)
In Park ign off= 0V
In park ign on=~8V
In park ign 'run'= ~8V
Truck Running (solenoid wire off)
In Park = ~8V
Even if you don't know the answer to these voltage issues, could anyone give at least the last one a try, it's real easy to measure, fire up your truck, pull the wire off the starter solenoid (above the pass. inner fender) and measure the voltage between that and ground (neg batt terminal) I would appreciate any help on this one!!!
In Park = 0.071V
In Gear = 14V
In Park ign off= 0V
In park ign on=~8V
In Park = ~8V
