BillRod
Hi All
Can anyone direct me where to find info on removing the electric Tcase shift motor?
My wife has a 94 Ranger 4.0, 5spd, ext cab, Pushbutton 4x4, manual hubs.
The last snow we had the 4x4 stopped working.
When I push the button I can hear the control module behind the drivers jump seat click but no dash lights come on and nothing else happens.
I looked through the transfercase section and found the sticky for the 4x4 system diag outline and followed that through all the steps. the Control module and the buttons check out ok. I have the 12 volts at the orange wire on the motor and 12v across the orange and yellow wires as stated int he sticky. But still nothing happens other than hearing a click at the control moduling when I push the button.
So it looks like I need to replace the electric motor.
I looked through the this section but did not see any posts about removing the motor. I also searched but I must not be using the search correctly because I also could not find any info.
Thanks in advance for any help on this.
Bill
Also when diagnosing the issue using the sticky mentioned above there is one section I have a question on. I copied below and it shows sequences of opens and shorts. When I put my ohmmeter across as directed I only got the first response in each line. Either open or short but it never flashed or moved to the next thing in each line.
I'm confused on this one.
OHMMETER READINGS FOR SHIFT MOTOR POSITION SENSOR
Pin 8 Y/W To: TRANSFER CASE MOTOR POSITION
2 High Edge 1 2H-4H Edge 2 4 High Edge 3 4H-4L Edge 4 4 Low
Pin 4
P/Y Short Short Short Short Open Open Open Short Short
Pin 5
W Open Open Open Open Open Short Short Short Short
Pin 6
BR/W Short Short Open Short Short Short Short Short Open
Pin 7
O/W Open Short Short Short Short Short Open Open Open
Bill
Pin 4
Pin 5
Pin 6
Pin 7
