My point is that most of the "cheap" fans out there move nowhere near what the stock fan does. If you have an auto trans. and are doing a long, slow climb, that crappy electric won't keep up. Like I said, don't be cheap. I've had pretty good luck with the stock Taurus electric fans. Dependability is much better, they move lots of air, have their own shroud and they are two speed. I usually wire the "high speed" to a manual switch and just use it on those ling climbs I mentioned.
If you do this, don't cheap out. Your new electric will hve to move a butt-load of air to keep up with the stock fan. You will notice no HP increase in your hinney dino. You will notice no substantial increase in fuel milage. The savings in drag will just be transferred to the alternator. Reliability is much worse with electric. If I did not need to shut mine off for deep water, I'd put the stock fan back on in a heartbeat. Unless you have a particular reason to switch, I wouldn't bother. Any gain you might see will be more than offset by the cost and trouble of the installation.
