Winger
- Aug 4, 2008
I removed the stock exhaust manifold and installed a Headman header on my little 2.3L wich of course doesn't have a bung welded in it for the EGR line to hook up to. I figured eventually I'd find some way to rig it up. Until then I just blocked it off on the intake and ran it that way. Of course with the header I had to move the O2 sensor further downstream in the exhaust wich caused it to see some cooler temps and it richened up the mixture a lot! The EGR line being disconnected didn't help matters out. I'm sure I'm not the first one to try some of this. I was hoping to find something along the lines of the steel braided flex lines you see for exhaust pipe applications only a lot smaller diameter maybe find some one that could make up a custom one? Anyone else fixed these rich condition without messing with the computer?
