Kenneth S
On my 88 ranger the previous owner removed and lost some of the pieces for the fuel injection, I have the intake manifold's, throttle body, IAC, injectors, fuel rail, fuel pressure regulator, injectors, all the sensors, and the wiring harness for the injectors, dist, and sensors. The plugs for some of the electronics on the trucks main wiring harness have been cut off. I am missing the high pressure frame mount pump, computer, mass air (it's a manual trans) and the wiring harness plugs into the computer that goes to the various components. I have searches the local salvage yards for the parts I need to put the efi back on it (I'm currently running a holley 350 2 barrel carb adapted to the lower square efi intake), but I've had no luck luck finding truck with all the efi components I need. Is there a easy to setup aftermarket mass air efi setup that's available. I can troubleshoot efi systems when all the parts are there, but I've never "put a efi system together".
