- May 23, 2012
- Automatic
I've been logging countless hours researching upgrading my 79" thunderbird 302 that I have in my ranger to an EFI setup. I've got almost everything I need to do this conversion, I'm going with a EFI setup with mass air, the wiring harness and ecm i'm using is out of a 89 mustang non-HO. I'm going with a 65mm throttle body and 70mm MAF(calibrated to the stock 19lb injectors). My question is the cam I have in the motor right now is a very mild cam with a power band from 800-4,500RPM'S to be exact the summit racing cam SUM-1799. When I convert over will I need to retune the computer for the cam. I know according to oldfuelinjection.com it says to keep the lobe seperation at or above 114, this cam has a seperation of 110, will that cause issues? If needed I can swap the cam, but that will be my last resort, if I need to do that will this comps cam work without a retune? Part Number-31-255-5 1,000-5,200RPM range, valve lift 0.462 int./0.474 exh and a 114 degree lobe seperation. thank you
