RonArt
- Sep 16, 2010
ECU question (1992 Mazda B2200 Sport fuel injected)
Though I have read on a few forums that people have replaced their ECU... I have not read that anyone suggests performing specific tests BEFORE installing the ECU.
The reason I am concerned is that I received back an ECU that stated that the solenoids/relays must have a resistance value of no less than 20 ohms or it could damage the ECU.
I called Mazda about this and they seemed clueless, but... they said that they do perform tests on the connector to see if there are any shorts, etc. prior to installing the ECU (so I assume this is probably what it is).
Mazda also said that they MUST reprogram the ECU after it is reinstalled for it to function properly.
No where have I read that this is necessary.
Mazda said that they charge $99 to 'reprogram' the ECU and if they have to diagnose it after that it would be an additional $99.
Does this seem correct or are they doing things that are unnecessary?
Any advice would be greatly appreciated.
Regards,
Ron
Regards,
Ron
