- Oct 11, 2011
Need an ECU for my 5.8/4R70W swap. The engine came with D9EL. This was from an 89 E150 with a 5.8/C6. The local wrecker has a line up of ECU's on the shelf. Unfortunately, no pick and pull here, so I must pick my application and trust the Hollanders.
What I've come up with is an ECU from a 94 F250/350 with 5.8/E4OD. It has part # F4TF-12A650-PA and code KEG0. What I can't confirm is that the application supports speed density and bank fire EFI. I strongly suspect it does, but before I spend the $100 for this no warranty part, can anyone confirm it does?
Thanks,
Thanks,
