- Sep 23, 2004
- Automatic
Did you at least test fit the springs to be sure they are going to work?
Was the side with the most washers the passenger side? Ive noticed after having my beams out agian that the pass side is about 10" shorter then the drivers. On my setup I have about 1/2" to 3/4" more spacer on the pass side beam to make the two sides level.
(about 1½" on the D-side)Did you at least test fit the springs to be sure they are going to work?
axle perch was raised 2.5" because the frame perches are raised 2.5" right?sorry to keep asking but in the thread it looks like you raised both the frame and axle perchesIf I hadn't raised the buckets then they would have been the perfect lift height.
