EB coils stock bucket_pic
thats the truck now, when i had the 6" ttb lift it sat about and 1" lower then it does now, also mine has 3" body lift on 36" tires
i have 5.5 wild horses coils in stock buckets. they do sit differently from right and left side. i cut a little piece ofthe left side coil so it sit better.
i also put some 2.5 inch tubing in the center of the bucket to keep the coils from falling out or moving around
hey tire tireiron your truck looks good!!!now is that a 5x5.5 lug or a 5x4.5 lug...and how about the hubs? they look like RBV type hubs?
I had these made back before I got my coilovers. 3/16th plate with a 2" peice of tube to hold the coil in. Im pretty sure they are still floating around my garage.
i got the heavy duty b. graveyard coil towers.. got the pass mounted.(using existing bolt holes. what did you do for the driver side (big ps hump)
not sure, i drilled all new holes for mine and used plate steel behind it to angle it out, but my 1st swap on my explorer i used '79 full size spring towers, on my ranger sas i used stock buckets
