pxbacher
OK, so this doesn't make the WHOLE install easier, but it does make the part where you lift and maneuver it into place WAY easier, so here some pix...
I actually figured this trick out when dropping the trans, then again when putting in the new one. Again, I'm sure someone else probably figured this out before me, but posting anyway in case others aren't aware...
I knew there had to be a better way while trying to pull my trans and at the same time balance it on top of a floor jack. While staring up at it from below, I got this brainstorm... HANG the trans from a strap, maneuver it out (SUPER easy, because you can twist, turn, pull, and wiggle it effortlessly, without worrying about dropping it or having it fall off a jack), then lower it from above.
I put a black pipe cheater across the shifter hole, then ran a strap from it down and around the trans. Doing it this way made the removal a piece of cake! The install was still tricky, but I did it without a jack and by myself. The hard part is raising it up while keeping the ratchet accessible, but once you have it raised, it's cake to get it into place (over the Y-pipe, in my case).
Pipe and Strap from above
Hanging Trans
Ratchet with Room
Hope this description and the pics help somebody.
-Pete
Hanging Trans
Ratchet with Room
-Pete
