- Nov 19, 2018
- gettysburg, Pa.
- Automatic
Finished up the install of the gas filler today. Flipped it around into the bed and used the pocket used for the tie down. fabed a new bracket and welded it in cut the hole for the filler pipe. old filler pipe had to be modified to fit in the reversed position. Sticks out to far and hits the inside of the fender. Ruined original filler pipe when welding on it and found out the inside filler that holds the gas cap is plastic. Received new filler tube and used JB weld to hold the modified tube wrapped a little fiberglass clothe around it for added strength. Looks like it should be ok will need some new longer rubber hose and vent tube.
