- Jan 25, 2010
- Automatic
Will do. I think it is a motorcraft 2150You said you are not using the advance on the distributor did you plug the vacuum ports coming out of the carb. Depending on the carb you have find the one that gets vacuum when you open the throttle and connect it to the distributor just a plus for the future owner will add gas mileage.
