- May 23, 2019
- 2.3 (4 Cylinder)
- Automatic
- Tire Size
- 15"
So, is that what we're looking for, one Ohm of resistance? That doesn't seem like much.
I figured but thanks for the link with dimensions. I can find that at a local industrial hardware store.Yes, metric.
Those I have, thank goodness.These are what the other four should look like.
6 is way too high. The Ford spec is 1.05 to 1.15 ohms.Resistor wire is measured in ohms per foot.
@19Walt93 knows the internal resistance for a duraspark coil. Seems to me everyone i checked over the years was right around 6 ohms.
Think of the ignition coil like a tank you are filling with electricity. When the module first grounds the coil and the coil starts filling up with energy, to the circuit and the module it looks like a dead short for a instant. The small resistance in the circuit throttles the amount of current that is able to pass through the circuit, and the module is part of this circuit. As the coil fills up, the amount of current is less and less.
That is why the module tends to fail without the resistor, there is too much current going through it. 1 ohm is not much resistance, but it is enough to drop the voltage across the coil from 12 down to 9-10v when the engine is running.
The Ford TFI and the GM HEI both have current limiting circuits built into the module, so they do not need external resistance.
So that manual says the ballast resistor can be .8 to 1.6 ohms and still be serviceable.Manuals are our friends.
Nope, if I remember right it's 1.1 to 1.3 ohms. Lower resistance will make a little hotter spark but your module will die early and often.Resistor wire is measured in ohms per foot.
So, @ 1.4 Ohms am I OK with the NAPA coil or should I go with the Accel coil and in-line resistor (kinda lost now)?Nope, if I remember right it's 1.1 to 1.3 ohms. Lower resistance will make a little hotter spark but your module will die early and often.
