- Dec 6, 2009
- maplevalley WA
- Automatic
I dont know if it will fit on a holly carb. The advance goes to the ported vacume port it will have no vacuum at an idle until you open the throttle. Take some pics of the carb will help a little better. There are two check valves for the air system one goes to the cat and the other goes to the crossover on the back of the heads you can try just putting a hose connecting the two as long as both check valves are still working That way you dont have hot exhaust going through the hose otherwise you can cut and crimp the tube as long as you dont have to pass smog tests.Kim can that be used with a Holley carb? I'm getting pretty close to being done with the conversion. I've had some other issues to take care of in the process and have been taking my time. A few things I'm unsure of with the Holley carb is vacuum hook ups and the throttle and choke hook ups. It looks like the throttle linkage stud needs to be swapped out to a ball stud instead of the flat on so the cable can be a hooked up correctly. I'm also not sure if I left the electric choke wiring when removing all the junk. What should I be looking for? Also how did you guys go about blocking off the smog pump pipe to the cat?
