- Feb 2, 2013
How did the #41 jet's perform for you?
The ones in the eBay carb I tore apart were #47, probably for a 302 originally.
Also, I learned that this is a 2100 carb from approximately 1973 yr.
it has the "vacuum break" on top of the carb just opposite side of the bowl. It is a diaphragm assembly. Not real sure what it is for or what it does but the spring is rotted and I'm trying to figure out whether or not I need to replace the diaphragm and the spring (which does not seem to leak air/ vacuum).
If I replace the thermostat housing on the carb assembly, the auto choke will still work? Or is this simply a way to plug the vacuum that would leak.
Also, you say to use the fel proi kit you listed. Is this to plug vacuum ports from the bottom of the carb or simply to raise the carb from the manifold? From what it looks like on the stock setup, there is already a carb spacer on there?
