2.3L ('83-'97) Duff Cab Mounts (89 2.3 Ranger)
MaD
AZ
2.3 (4 Cylinder)
Does anyone know which order do the Duff tuff can mounts go. I'm guessing based on size is from bottom to top is front, middle, rear.
I remember when I did my Bronco II, there was no apparent reason to their thickness, I had to reference how thick the original was at that certain spot on the frame.
  • Like
Reactions: MaD
Not sure but I should probably get a kit myself, I think the cab is resting on the frame in a few spots on my '90...
  • Like
Reactions: MaD
I will warn you the aftermarket plastic bushings are a little noisey. You will hear a lot more road noise and transmission/driveline noise with the harder bushings. But one positive note, it really stiffened the whole vehicle up, the thing corners like it's on rails after the plastic body bushing swap.
  • Like
Reactions: MaD
