Dually Ranger?
There were factory cab/chassis options but no factory duallys AFAIK.
Sharp lil truck though
Jim did an article on this awhile ago...
I think this is about the coolest one I've seen...
39922
I thought there was a special camper model that had a dually?
Edit... this thing
The Roll-A-Long had a dually axle. IIRC the dually setup used was a conversion kit using Toyota Buddy parts.
Back in the early 80's when small pickup's came out there were a ### of aftermarket companies that came out with dually kits for them.
There were also a lot of truck camper companies that made campers for the small pick up's and advertised heavily in the RV magazines, along with the dually kits.
You could even get them from JC Whitney.
Problem with them is they would adapt the stock rear end, which was never intended to hold up to that much weight.
Grumpaw
Grumpaw
Can't tell if this is an old camper converted to a flatbed, or someone's creation. Did ranger come as a dually option? Or was that an aftermarket add on?
I’m going to say that’s someone creation. The rear axle looks like an old Toyota cab/chassis dually rear (6 lug) and the front is 5 lug. Any self-respecting company would at least try to match the lug patterns.
Grumpaw
It also has the effect of giving the tire a larger amount of leverage against the bearing, which causes increased wear on the axle shaft bearings.
I've never seen a 6 lug full floating axle but I'm not really Toyota savvy. :dunno:
There were actually quite a few of them made. Even Uhaul had them...
39940
Here ya go....Just google up Ford Ranger Dually and dozens of pic's come up.
Grumpaw
I want that Ranger so bad.
I don't know who has or hasn't read the article on that truck, but it has a 7.3 PSD.
It's a bad mo fo
