Zauna
- Sep 14, 2011
Hey guys.. Well I just did a Diagnostic Code check on the Ranger and was able to pull Code 23 Which is "Throttle sensor out of range or throttle set too high - TPS ". What does this mean? Bad TPS? Also are these adjusted when replaced? Or is it something you just bolt on when replaced?
Been having som problems starting the first time, usually starts second time.
