so in november/devember, my e-brake wasn't disengaging fully, especially when it was really cold (-20) so i was told it could be dirty brakes, so i replaced the pads, cleaned the backing plates as much as i could and put it all back together, it worked for the most part, they disengaged, but the pedal wouldn't quite come up enough to turn the light off... in december i had my truck in, they replaced my rear diff, replaced all 4 axle seals and cleaned the backing plate, i haven't driven it much since then, as i've been out of town, i hopped in my truck last night, after it sitting for over 24 hours, and the whole truck felt like it was frozen... i take my foot off the gas and it's like i slam on the brakes, i assumed this was the 75-140 in my rear and the 75-90 turning to a solid like state because it was -28 on my mirror (which dropped to -34 while driving) after driving out of my buddy's subdivision and letting it warm up a little, it loosened up a little, while driving down the highway (i was only doing like 60km/h (35mph) it felt fine, till i hit a traffic light, as i stopped, i could tell the rear brakes were on for sure, as it was a downward hill and i stopped, then i noticed a lot of smoke passing the passenger side, and could smell burning brake, turn the truck off, the drivers side is cold, the passenger side rim is warm to the touch (ambient temperature is -35ish) and smells bad, not to mention i can see smoke coming out of it...
i tried to drive forward but that one wheel was locked for sure, put it in 2wd and dropped the clutch, got both wheels spinning, pushed the ebrake pedal all the way down, and snapped it back up a few times, it seemed to be released at this point, so i drove the rest of the way home... when i got home, i could still smell burning brakes, but didn't check to see if the rim was warm, went inside and went to bed...
what i'm wondering, is there anyway that the dealership screwed something up that would cause this? what could this be caused by?
