If I were to get extended radius arms, would I no longer need the drop brackets that are currently on my truck?
No you won't
just extend them back to the frame with the right alignment stuff and you'll be fine.
he means you won't need the stock crossmember or drop brackets, it'll pretty much be all custom back there afterwards.
Correct, so I will need stock suspension brackets and I will be using the crossmember that comes with the kit. I may have it all wrong though...
no, no, no....You will still need the pivot drop brackets.
