Drop bracket question.
Rngr88
Pa
I have an 88 ranger and it came with a James duff 3 inch lift with 3 inch drop brackets can I put a 4 inch spring in place of the worn 3 inch spring without jacking up the camber too bad?
Should work no problem unless you have a standard-cab & 4-cyl engine, then it could be iffy (might work, might not... having a winch & bumper mounted up front would better your odds in such a case).
Awesome thanks I have a extended cab 2.9 should be good to go
