Dugan
For the ttb drops, are all the 4" ones also for 6"? Ive seen a few that say 4-6".
This is why I use to run full size.. so easy no issues. gah
the skyjacker brackets have 2 holes in them, one to run 4 inch coils and one to run 6 inch coils. not all brackets are like that though, my rough country brackets are just 4 inchers
Yea.. but I dont think they are even... The bottom hole I use for the passenger beam while I use the top hole for the drivers side beam.
This was the only way to get my camber I wanted... Im going for about 4.5-5" of lift....
yeah, i've heard that before.....maybe the brackets will just work with either size coil and the front end will still be alignable (if that's a word)
at a 4in drop with a 4 in spring, the camber theoretically should not have to be messed with, but the toe will be way out and thats easy to change
