warrior24
My story goes as follows. I had a squeak when I went in reverse and increased as I accelerated. I replaced my u joints, all 3 of them and also the center support/drive shaft bearing. Then the squeaking stopped but now when I hit 43 mph I hear a vibration, which sounds almost as if I have subs. The sound is hard to pinpoint as it seems to be causing the whole truck to shake at an ultra high frequency. I crawled back under the truck and recheck the u joints which seem fine. One observation I did notice was the driveshaft fork that comes out from the tranny (A4ld) has a bit of wobble. Should I suspect a bad bearing in there? If so what's my next course of action?
I did not hear this noise before I replaced the drive line, so I don't suspect a bent axle or lumpy tires
