I did a 4 inch lift, and while we did it, we noticed the carrier bearing was shot. The rubber was just shredded. We replaced the bearing but We had alot of chatter afterwards until we adjusted the bearing. This was done by grinding off the rivets that hold the support crossmember, and then driving them out with an air hammer. Next was a drill to clean the holes up a little for some nice big bolts. Grab a ton of washers and add them between the crossmember and frame and snug it up. Of course, there's not a lot of room to work there, so doing it once is a pain, but guess what? Unless your lucky with your guess if washers, you probably have to add or subtract more washers. Take it for a ride, and see how it is.
Repeat the process until the vibration is fixed.
Or skip the process and swap in a one piece. I learned the hard way that this is so much easier.
