Driveshaft bolt torque
meatshieldchris
I've got a 1992 4x4 supercab, and I'm going to change my center support bearing today. I don't have my manual yet, but the bearing can't wait. Can someone give me a few torque values?
-the 12mm 12point bolts on the diff and transfer case side
-the smaller bolts on the yoke near the center bearing holding the rear driveshaft u-joint to the front driveshaft yoke
-the large nut in the center of the yoke near the center bearing ( holding the yoke to the front driveshaft )
Going to take it all apart and grease up the slip joint at the same time. Do I need to use loctite on the driveshaft bolts? Blue?
Which is? I'm pretty sure that bug nut takes more than that...thought it was in the 100 range.
