ati190
After searching through various scenarios, I've discovered my driveshaft may be out of alignment, causing vibration. Can anyone tell me how to check, and get this driveshaft back in alignment?
Thanks
ati190
EDIT:
The long driveshaft is definately in alignment (both ends of the shaft). Both yokes go vertical and horizontally with each other perfectly. However, the short shaft that slips into the trans does not align. The front yoke is vertical, but the end yoke sits an angle, While the yokes are vertical on the front, the back does not sit horizontal.
Thanks
ati190
EDIT:
