drive shaft with 6" lift on a 91
venom97
central,il
03-4/5 91-8.5''
ive got a 91 ext cab 4x4 that im going to lift 6''. ive heard about swapping to a 1 piece drive shaft. will i be able to run my 2 piece for a little while till i find me a one piece? thanks guys,sorry for the stupid question.
Yes you can run the 2 piece shaft for a bit, I did on my 91 with 6" lift. I had to drop the crossmember that the support bearing of the driveshaft is mounted to down about an inch or so so it didn't vibrate as bad. I'm now running a 1 piece steel shaft out of a 98 ranger.
thanks,the 98 shaft is from an ext cab 4x4 as well?
Yep. Anything else would be the wrong length.
