doors shake?
poorboy4x4
Arcadia Cali
does anybody elses truck driver and passenger doors shake when driving? is htere bushings that need replacement? are there mysterious bolts that need tightening? or is it just normal?
check the position of ur striker pin, if it has been moved out it may not be creating the proper seal with the weather stripping, also check to ensure ur weather stripping is all there as well as ur door pins which like to wear oun and will cause a up and down shimmying of the door....
door pins? thats exactly the movement im getting, up and down, ill check that, thank you:icon_thumby:
