Door will not stay shut keeps bouncing open
SRD
Forum Member
Las Vegas
I went out today and the truck door will not shut at all. If I close it; it pops back open illuminating the center dome. If I hold it shut the center lights shuts off. The past few days it popped open a few times while driving over a bump...I thought nothing much. Today cannot shut door enough to drive it at all.
*I tried to clean the latch and it moves with screwdriver but nothing I did works.
*Any Tricks to keep door shut would be awesome. I rather not pull door panel but will if I have too and if that is required for repair.
Thanks.
SRD
Take the 1st picture from the passenger side. I think you'll see a difference...
Might be time for some spray lube on the latch pivot points. Or, pull the seatbelt inside so you’re not closing the door in it. Are the hinge pins worn? Will it close if you lift up on it?
Event Coverage
TRS Merch
