DOOR Sensors, where are they?
flashesbuck
Ok i have looked everywhere for these things. I have also been searching the forums and have not for a picture of these things... i look everywhere on the door, inside the door but still cant find the button that triggers the light the dash.
When it rains or gets wet inside the doors the sensor acts up. so when its raining sometimes it triggers the alarm. also the light stays on so i ripped it out.
i have loaded some pics up here so can someone point them out for me?
its in the door latch itself. before you tear it out shoot some WD-40 down into the latch and work it in a little and see if the problem persists. believe it or not but the WD-40 trick works well for the door ajar problems.
edit: i just happen to have a pic of the latch assembly out of the door. the part that my thumb is on is the door sensor.
thank you so much, i coated it down with lub last night and well see how it works out.... i have had this truck for 7 years now and have had no dome light for nearly 6 1/2 years.
thank you again.
no problem man, hope it works out for ya. let us know what you find out.
