nobbyv
- Dec 4, 2007
- Automatic
I searched and read all of the threads about the switch on the door latch getting gunked up and sticking open, leading to the dome light staying on, and the WD40 fix for it. However, my dome light stays on no matter which of the three positions the switch on the light is in: Off/On/Door. Also, I get no erroneous "Door Ajar" warning. So this doesn't sound like the door latch switch issue ( I did spray them down w/ WD40 and try opening/closing the door a few times just in case, w/ no luck). I have verified that the dimmer switch is not all the way up.
So am I the one guy that actually has a bad switch on the dome light itself, or am I missing something else? It's a '97 standard cab, FWIW. Two bulbs.
