Doing the plugs and wires
SpeedNinja
South Florida
I've had them around for a while now, but I'll be putting them in soon... hopefully this weekend. I just gapped the plugs at 0.044" tonight (Autolite XP Iridium). I've also got Bosch wires, and I'll do the PCV while I'm in there.
I'll try to get it done by unbolting the throttle body and upper intake. I need to clean out the throttle body anyways. I'll try and take some pictures of the process, and list any ways I think it could be done better.
ALL you need is a swivel, extension, ratchet, appropriate size deep well socket, and a long set of needle nose pliers or long plug wire pliers.
You do not need to remove anything but the plugs, and wires. Maybe the throttle linkage cover..
it is easier to remove the upper chamber it is quicker and less swear words. if you are careful you can reuse the gasket if not, it is just 6 bucks
