mysticclam
- Feb 8, 2010
- 4.0 V6
A friend of mine with a 2.5L said he was driving home when his truck "just shut off"
It wouldnt retart so he had it towed home.
I went to look at it yesterday and the battery was fully charged. When you turn the key there is a loud clack from the starter then no sound. As long as you turn the key, the voltage at the batter goes down considerabley so I think the starter is trying to turn. We put a wrench on the crank bolt and cant get the motor to budge. I think the motor is siezed. Oil level was just above the add line so a little low. The oil also smelled like gasoline but wasnt thin or anything. He has been saying he is only getting 14 mpg for a few months. Im wondering if he lost an injector and has been pouring gas into one of the cyliders disolving all the lubrication. No check engine light though. You would think that would run it really rich.
I should also add this vehicle was used for courier work and this is the second engine for the truck, it was a rebuilt when put in and now has 180,000miles on it.
