- Jun 1, 2025
- Age
- 76
- State - Country
- FL - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.3 (4 Cylinder)
- Manual
- Tire Size
- 14"
Did a clutch job when my flywheel came loose after 8,000 miles on my previous clutch job where I changed ALL parts; I didn't Locktite my bolts. I tightened and Locktited my flywheel, put in a new clutch and pressure plate, pilot bearing, but did not swap out the master nor slave. For sure I had trouble getting the bell housing back on and, yes, used the bolts to draw it in.
Now after bench bleeding the master, I'm unable to gravity bleed the slave. I bought a hand vacuum pump. I tried it on the Master reservoir, but was unable to create a draw to suck fluid into the system. I then tried the vacuum on the bleeder of the slave. I was able to get a very small amount of fluid under a decent pressure, but never without pressure.
Any idea what these symptoms mean?
Thanks,
Allen
Thanks,
Allen
