- Jun 16, 2009
- New Hampshire
- Automatic
Hmm! I'm wondering why one of the gasoline companies doesn't incorporate whatever it is in these wonder additives? If the shit really works, whichever gasoline company puts it in their gasoline would outsell all the others!
Oh I get it! If one does it then all the rest will add it too...then there won't be any gain..so why add it in the first place?
"Upper cylinder lubricant"... Where in the hell is it? And why would it need special lube?
Someone needs to tell Ford, GM, and maybe even MOPAR. Then perhaps the engineers will provide a method of lubricating that place.
P.T. Barmun was indeed correct. He is laying there in the dark six feet deep...clapping his hands in joy.
Big Jim
They do put this stuff in. Chevron Techron goes in their gas too. Some things don't seem to work but I don't know why someone could not believe that concentrated solvents can clean deposits. That is all it is. Do you think injectors stay clean forever in all motors? Valves never get dirty? The deposits never affect the way an engine functions? Is the only way to clean injectors to remove them and then what? You run solvent through them.
All gas is the same too right? No difference between name brand and generic? None are ever dirty and none leave deposits of any type?
Does the MAF sensor stay perfectly clean for 150k plus? The air is filtered so it should. The throttle body never gets gunked up either. That same gunk somehow disappears before it gets to the valves? The unburned fuel from the EGR systems never gets anything dirty either.They made carburetor cleaner for a reason. The carbs got dirty, visibly dirty. So do injection systems.
No need to flush radiators and cooling systems either is there? The stuff is good for 5 years and never leaves any scale or impurities, right? Why change the fuel filter? The gas is pure from the in ground tanks. Not. Does the fuel filter catch all impurities? Of course not.
I can't figure out why you'd want a lubricated upper cylinder either. After studying oil I have come to the conclusion that it is GENERALLY not a good idea to add anything to that. I don't see the problem with adding additional solvent to fuel on occasion, especially if there seems to be a problem.
As far as oil companies adding chemicals and automatically outselling others, cow puckey. If you build a better mouse trap the world won't do crap. You need to market it like Shell and Chevron. Then people need to buy your marketing effort.
Funny post though. Of course some stuff is junk, or at least less effective than other products.
