does anyone know about super lift kits
  • Thread starter Thread starter riverhunter_88
  • Start date Start date
riverhunter_88
Guest
does anyone no what hole do u bolt ur ttb up to the top hole or the bottom
I would go with the Skyjacker #FA600 drop arm. Modifying the steering kit gets pretty deep if you don't know all of what you're doing. But yes, the pitman arm that otherwise comes with your kit will not be enough to properly correct your steering linkage angle.
So the Skyjacker pitman arm has more offset than the Superlift one?
Much more. It will actually fully correct your steering geometry with a 4" lift (but will still work acceptably with a 5.5" lift). Shorter pitman arms will put you all over the road at 5.5" lift (not to mention will greatly shorten the life of your tires).
