does any1 else have a 4inch lift and 33s with bad rubbing
93ranger4.0
im rubbin pritty bad on my control arm an dont wanna drop tire size what are my options? im thinkin wheel spacers but havein trouble finding them for a good price for the truck any advice would be awsome
A different offset rim (I don't remember if it's a greater offset sticks the wheel out further, or if it's a smaller offset...double check that) will stick the wheel out further. However, this is more costly than spacers, and you can run into troubles with the local law enforcement if they're sticking outside the fenders (depends on where you're from).
Uhh...a differently designed radius arm would work too...angled in slightly towards the center of the rig will prevent some rubbage. Cost will be a factor in this, or fab up your own.
do u know of any companies that produce the spacers for rangers?
You can also adjust the stops on the knuckle so it doesnt turn until it rubs...
if you use too big ofspacers youll probably run into rubbing issues on the fender behind the front tires when you go to turn, it did it to me and i had a six inch lift and 33s.
CUT cut cut cut that is what I did.
Featured Ranger Based Vehicle
